9.3.1 Joining points to polygons
5437
12-16-2014 10:05 AM
KeithTanner
I'm using 9.3.1, (at least until I finish this project) and have hit a snag. I'm trying to do a Join between a Geocoding Result and our subzone layer.  I'm getting an error message:
     Can't create output feature class.
     The Field type is invalid or unsupported for the operation. [GLOBALID]
     The field is not nullable.
I've gone into the Subzone layer and turned off the GLOBALID field, but still get the error.  Any help would be GREATLY appreciated!
XanderBakker
Esri Esteemed Contributor
Do you need the GLOBALID field in the resulting featureclass? If not, remove the field or make a copy of the featureclass and remove the field there.
XanderBakker
KeithTanner
THANKS Xander!  That did the trick!  I found how to go through ArcCatalog and remove the GLOBALID field.  The join worked flawlessly after that.  THANKS again!
