Which SDE tables contain the Distributed Geodatabase Replica Logs
2165
01-17-2019 10:03 AM
RandyKreuziger
Which SDE/GDB tables contain the replication logs?
I'd like to write a job to verify that the replication is taking place daily and that it's successful, if not, send out an email alert.  Has anyone done this already?  Thanks.
Env:  SQL Server 2012, SDE 10.4
George_Thompson
Esri Notable Contributor
I do not think that log file is within the geodatabase system tables. They are usually located here:
Replica Logs
File(s): ReplicaLog.dat
*Note: You can change the default location in the Distributed Geodatabase toolbar in ArcMap:
i.e. Distributed Geodatabase > Properties > General > Logging Properties > Log file path
A quick tour of replica management—ArcGIS Help | ArcGIS Desktop
The replica activity log—ArcGIS Help | ArcGIS Desktop
--- George T.
RandyKreuziger
I'm having a problem finding it.  The original data is onprem with the replica up on AWS.  The sync is run as a scheduled task up on AWS owned by me but run using an shared AD service type account for use running scheduled jobs.  The ReplicaLog.dat under my C:\Users\<user_name>\AppData\Local\ESRI folder is completely empty size 0KB and there is no ReplicaLog.dat file in the service account folder.  I made sure that file explorer is set to show hidden items.
George_Thompson
I would think that the file is located on the client machine that runs the sync. I would also make sure that the log level on the client machine is set to anything but "NONE".
--- George T.
