Update field dynamically in Enterprise Geodatabase
1178
11-30-2022 11:51 AM
aam
Is there a way to dynamically update a field in the attributes table? I have a field for URL which I want to automatically populate anytime a new record is created and a unique ID is provided for that record.
MarceloMarques
ArcGIS Pro - use Attribute Rules
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/an-overview-of-attribute-ru...
ArcMap - you can use the Attribute Assistant
https://solutions.arcgis.com/shared/help/attribute-assistant/
These are out of the box, but there are other ways to achieve the same, like to write you own ArcObjects tool, or use Database Triggers, but those will require advanced programming knowledge.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
