ST_TRANSFORM on multi polygons fails
3916
05-31-2016 02:41 AM
irishadar
When using SDE.ST_TRANSFORM on multi polygons that has self interaction
return error:
ORA-20603: Spatial References are not compatible.
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 720
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 2704
The problem is on 10.2.2 it works well on 10.4, any idea what to do on 10.2.2?
thanks
Iris hadar
IAA
George_Thompson
Esri Notable Contributor
Hi Iris,
This may be a known issue with 10.2.2 that was corrected in a later release.
BUG-000086328: Performing a transformation on a feature class in an Oracle database using the ST_Transform is producing a transform error: ORA-20603: Spatial References are not compatible.
http://downloads.esri.com/support/downloads/other_/104-IssuesAddressedList.pdf  - List of 10.4 fixes
http://support.esri.com/download/2266  - List of 10.2.1 UTUP4 fixes
I would reach out to technical support and have them investigate in more detail to verify that you are encountering the same issue.
--- George T.
irishadar
thank you ,
It is working on 10.4.
I found a work around  using sql to convert from multi part to single one .
iris
