the version could not be reconciled ORA-00904 B type :Invalid Identifier
5173
5
05-01-2016 08:27 PM
SibghatUllah1
I am getting this error when i am trying to reconcile.This error is saying of some column conflict.Please suggest anything?Arcgis 10.4 oracle 11gError.JPG
SibghatUllah1
I have checked the locked mode and type also.
George_Thompson
Esri Notable Contributor
Does that feature class with the issue have a join on it in the child version?
Have you run a compress first then reconciled/posted?
--- George T.
SibghatUllah1
FC is not joined and i am trying to reconcile first .
Should i have to run compress first?
SibghatUllah1
I am still facing the same error can some body guide me to fix it?I have checked compare schema tools and found no changes.if i just take back up of both default and child versioned and after that load all the data in  the default version? Please suggest me any solution.
George_Thompson
I would recommend opening an Esri Technical Support​ case to have them investigate in more detail.
--- George T.
