SQL Table to Domain
2142
08-22-2023 02:38 PM
vijaybadugu
We have plenty of Non Spatial SQL Tables with two fields one is code and other is description with unique 100s of records. which is used in other applications. Is there any way to use same table as domain and assign them to fields in ArcGIS Pro?
MarceloMarques
You need to convert your table into a Geodatabase Domain.
Table To Domain (Data Management)—ArcGIS Pro | Documentation
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
vijaybadugu
Table to domain tool is not accessing SQL tables ?
clt_cabq
in ArcGIS Pro search for Table to Domain in the geoprocessing tools, this should do what you are wanting. This will create a domain in your geodatabase that you can then assign to the appropriate table/field. You may have to work with your GIS data to make sure the existing values correspond exactly to what is in your new domain.
vijaybadugu
Thanks a lot for your answers. I just did converting table to csv and used same tool to convent to domain
