Spatial view registered in another instance
886
11-24-2020 09:26 AM
MichaelGinzburg
I have an ArcSDE 9.3.1 installation.
I need to recreate spatial view.
After I issued sdetable - o delete I'm getting error message that the view "is registered in another instance".
Afterward sdetable -o create reports success but the view is not created - I can't see it in ArcCatalog.
Did this after restart of ArcSDE service, and check that there's no connections.
There are 2 instances: SDE and the other.
It seems I need to unregister the views before delete. Will sdetable -o unregister unregister view from all instances?
Thanks!
VinceAngelo
Esri Esteemed Contributor
ArcGIS 9.3.1 is very ancient. It's unlikely many here remember how the old command-line tools worked, or how to work around geodatabase corruption with the old-style geodatabase architecture. It would help if you provide details on the RDBMS and how you've deployed the software. It sounds as if you have Oracle with the now-deprecated user-schema geodatabases, but exact details are necessary.
Generally, untangling a corrupted geodatabase would be a Tech Support call, but you're nearly a decade late for that. Any advice you receive now would come with a high risk of complete destruction of database integrity, so you might need to provide legal cover to anyone who could help (which would require a time and materials contract with appropriate indemnity).
The good news is that the pre-10 geodatabase architecture was more relational, but the bad news is that you're likely working without a net. Sorry.
- V
