Spatial Reference for A Registered Spatial View
2320
6
08-21-2023 02:06 PM
vijaybadugu
I am using ArcGIS Pro 3.1 and couldn't set Spatial reference for a registered Spatial View. it always throws same error that "Can not alter the spatial reference because the feature dataset is in use by another application/user." even though I killed all connected users . have been facing issue for 4 months and raised a ticket with ESRI Support team and they end up with a BUG. Do you guys have any workaround for this
DanPatterson
MVP Esteemed Contributor
BUG-000134031 or one of these
Esri Support Search Results
... sort of retired...
VinceAngelo
Esri Esteemed Contributor
If it's registered, then there's a layers table entry which could be UPDATEd.
Personally, I mostly just use Query Layers, which don't require registration.
- V
vijaybadugu
general practice, we use SQL View query, which includes, non-spatial fields and shape field. then, we register with Geodatabases.
VinceAngelo
There's lots of variables here: The RDBMS, the frequency of data layer creation, the mechanisms used to maintain data contents, use of versioning, availability of SQL admin tool, individual DBA comfort with direct SQL queries,...
I often have a SQL script to paste into a DB client (pgAdmin,...), with a follow-up ArcPy script to register as necessary. I once had an ArcPy script that loaded 40 tables into a temporary schema with FeatureClassToGeodatabase, then issued tens of thousands of SQL statements through ArcSDESQLExecute cursors to repopulate the 400M row publishing database.
- V
vijaybadugu
Thanks for your suggestion. I created new a Query Layer in arcgis pro from select statement of view and it worked and I was able to set spatial reference too
Yogesh_Chavan
Hi @vijaybadugu,
We were also facing this issue and while researching this post was encountered.
Can you kindly share the BUG number ESRI logged for this issue? And is there any updates on what happened with that BUG? Did they just closed it or have it planned to be fixed? We are observing this on 3.3 as well.
