Release lock on file geodatabase so it can be deleted in a python script?
4457
08-02-2021 01:17 PM
Labels (2)
MaryroseKulick
Hello! I am working on a script that will archive layers from AGOL in a zipped geodatabase. When I get to the clean up section, the script fails, because it can't delete a geodatabase with a lock in it. The lock is created during the script processes, so it's not being used by another user. Is there a way to release the lock in the same script? Here's my general workflow:
1. Log in to AGOL
2. Create a geodatabase
3. Copy layers from AGOL to the geodatabase
4. Zip the geodatabase
5. Delete the unzipped geodatabase (script fails here due to lock)
I'm very new to python, fyi. 🙂 Any help is appreciated!
MaryroseKulick
Update, I fixed the problem by using arpy.management.Delete() instead of  os.remove()
Thanks for the input!
DanPatterson
MVP Esteemed Contributor
The lock will not be released until the script is done.  You can use arcpy.env.overwriteOut = True to simply overwrite the existing gdb's namespace the next time the script is run.  Sometimes a bit of fluff lies around if you don't want to delete things manually or in a separate script
... sort of retired...
MaryroseKulick
