Point features not displaying
4665
10
02-05-2024 10:25 AM
KelseyM
I have a points feature class located within a file geodatabase feature dataset. When I bring it into my map no features display, however the attribute table is fully populated. I've tried to export the feature class to fall outside of the dataset at the root level and get the same results. When I export the feature class to a shapefile, the shapefile plots as expected displaying all of the features. I've tried clearing my cache and updating the spatial index with no results. Also selecting a feature within the table and trying to zoom doesn't work or change the display. Feature class has ~300,000 features and is distributed throughout Canada.
Has anyone encountered this before?
SarahMakin
Just found this thread experiencing a similar problem.
I had just copied features (points) from one layer and pasted special into another layer (points) that I had built using the template from the original layer.
After pasting into the new layer, for some reason the attribute table was populated but I couldn't get the points to display. If I selected the general area or all features within the attribute table, I could see the highlighted position of the points, but couldn't get them to display without selection. No filters, changed the symbology, turned off scaling restrictions, edits to the table had been saved. Nothing.
I would up removing the layer from the project, then reopening it, then they displayed fine. Maybe just a dumb little display bug. I'm using ArcGIS Pro 3.5.3 - 2025
