Ora 00001: unique constraint (SDE.R5_SDE_ROWID_UK) violated. SDE.GDB_Item Relationships
3680
07-03-2017 02:00 AM
filippobianchini1
Hi all,
I am currently trying to create a new feature class in my Oracle SDE geodatabase and I get this error: "Underlying DBMS error[Ora 00001: unique constraint (SDE.R5_SDE_ROWID_UK) violated] [SDE.GDB_Item Relationships]".
I have tried to align the sequences following these steps:
1) check from table TABLE_REGISTRY the REGISTRATION_ID of SDE.GDB_Item Relationships table by issuing the query "SELECT REGISTRATION_ID FROM TABLE_REGISTRY WHERE TABLE_NAME = 'GDB_ITEMRELATIONSHIPS'". the query returned 5.
2) I moved forward the sequence SDE.R5 till value > the maximum value of the objectid of GDB_ITEMRELATIONSHIPS.
3) In ArcCatalog i tried to create again a feature class without succeding. it returned the same error.
Any advice?
Thanks in advance,
                                    Filippo
RexRobichaux2
Hello Filippo,
 Is this the workflow you followed to check and advance the sequence? Error: Underlying DBMS error (ORA-00001: Unique constraint (SDE.GDB_OC_PKC) violated)
Alternatively, can you try creating a dummy table in Oracle through SQL Plus with the same user / schema that you are attempting to use to create a new feature class in ArcMap / Catalog? Just something simple like:
CREATE TABLE <your_feature_class_name>(id int);
Then, refresh your connection in Catalog and see if this new table appears in the gdb table of contents. If it does, delete it through Catalog- then re-try creating the feature class in Catalog. I'm wondering if there was once a FC with this name and it has become orphaned in some of the gdb repository system tables. I hope this helps!
Best,
Rex R
