Manage geodatabase locks…but not as the SDE geodatabase administrator – Possible?
3153
9
09-06-2023 02:17 AM
JamesMorrison1
Hello Data Managers
Linux / Oracle 19c / Geodatabase 11.1 / ST_GEOMERTY - not real Schema just for this example: SDE, FORESTS, RIVERS, LAKES.
On our Test Database the Schema FORESTS holds several Feature Classes. These can have old locks on them. So when we try and add a Field to a Feature Class it is not possible due to locks. Or if we want to drop the Feature Class it is not possible due to locks.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/manage-geodatabase-locks.ht....
Naturally, we can drop the locks as the SDE User.
Right-click the database connection in the Catalog pane and click Administration > Locks. Right-click the database connection in the Catalog pane and click Administration > Locks. The geodatabase administrator requires elevated privileges to disconnect users.  ALTER SYSTEM SELECT_CATALOG_ROLE*
Is it possible to assign these two Privilege to the User FORESTS so they can delete their own older connections? I have the feeling this is not possible?
Can a User disconnect their own locks or is this just the job of the SDE User as the geodatabase administrator?
Feedback welcome.
MarceloMarques
Only the sde user can remove geodatabase locks because the sde user is the arcsde geodatabase repository owner.
Note, database locks are different from geodatabase locks, the database locks can only be removed by the database administrator via the sysadmin database user.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
A_Wyn_Jones
Hi @JamesMorrison1
You're correct that those privileges are required to drop connections as described here:
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-oracle/privileges-oracle.htm#...
You could grant these to the user directly in Oracle - please consider the impact of this though and test it to see if its your desired outcome.
I'd be asking why these locks are being held and turning into "old locks" - are you using feature datasets in your Enterprise geodatabase?
It might mean that users are actively using the feature class and potentially making edits to the dataset - is that a good time to remove their lock? Normally, a user would release their own lock by ending their ArcGIS Pro session - if the locks are being retained then there's a issue.
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
JamesMorrison1
Thank you very much for your feedback AWJ.
What impacts are you alluding to here?
No Feature Datasets. Just Feature Classes. Since I started with Oracle / SDE way back in 2004 we have always encountered these old connections. Never really found a reason for them.....we just killed them via a script run at night. So one editing.
Thanks.
RhettZufelt
MVP Notable Contributor
Do you have any services that are using these feature classes?
R_
JamesMorrison1
No.
A_Wyn_Jones
SELECT_CATALOG_ROLE is required to drop connections. It also allows for that connection to upgrade a geodatabase. This capability should probably not sit with your day to day user.
Which version of Geodatabase are you currently running? Locks should be terminated as soon as the user session is shutdown. At version 10.6.1 - a known bug with SDE on SQL caused some connections to become "orphaned" and would cause disruption when it comes to admin tasks i.e. changing a schema. I should make it clear that this information pertains to SQL databases which I normally work with (and the bug relates to).
Hope this helps you somehow!
https://support.esri.com/en-us/bug/accessing-a-geodatabases-locks-information-returns-the-bug-000110...
JamesMorrison1
AWJ - we have used all SDE versions 8, 9.x, 10.x now 11.x over the years and we always experienced  old connections. Since this a Test system the Developers are often changing the data model and so the old connections stop them. Hence my original question posted below. Thank you for your feedback.
However, my post this time was more on the question: Can a User disconnect their own locks or is this just the job of the SDE User as the geodatabase administrator?
RudraniChakraborty
Hello @JamesMorrison1
The data owner only has the privilege to view the existing locks at the dataset level by the following steps:
>>Start ArcGIS Pro and connect to the geodatabase as the dataset owner.
>>Right-click the dataset in the Catalog pane and click Locks.
If you want to delete the locks, we need to connect with the Geodatabase administrator user, which is sde user. Please check the "View locks on your dataset" section in below document:
Even though I am able to see the existing locks on my dataset with the data owner, however, when I click on disconnect, I see below error related to insufficient permission:
MarceloMarques
Bud
Esteemed Contributor
