Issue while creating Enterprise GDB with Postgresql
8899
11
06-03-2018 10:46 AM
JanakiGattu1
Dear Esri Enterprise Geodatabase Team,
I am having an issue in Enabling Enterprise Geodatabase. The architecture is as follows.
We have three VM's.
First VM - ArcGISPro 2.0(Installed Successfully)
Second VM - Postgresql (postgresql-9.5.3-1-windows-x64-------Installed Successfully)
Third VM - Server. (ArcGISServer10.6-------Installed Successfully).
Now when I am creating a Enterprise Geodatabase from the First VM where ArcGIS Pro is installed - I am getting an Error saying "Instance not available on Server - Failed to Execute Create Enterprise Geodatabase).
I have copied the Keycodes file generated from Third VM - Server. (ArcGISServer10.6) and has put in the local system.
How to enable this.
RexRobichaux2
Hello Janaki,
  It looks like the port #5432 is still being referenced as the instance name. What is the machine name of VM#2 (the PostgreSQL Server machine)? Try entering the machine name where Postgres is running as the instance input (Is it maybe geodb01b or geodb01a?)? See if that runs successfully.
rkolka
I just got  Instance not available on server
In the Instance field I had  host.name.eg:45546
For some reason ESRI wants  a , (comma) instead of a : (colon). This is not what RFC 3986 specifies nor does ArcGIS Pro doc mention how to specify non-default port.
If I changed Instance to host.name.eg,45546 then Create Enterprise Geodatabase was success.
