Is there a way to view the guid of an sde replica?
905
06-13-2024 07:50 AM
WilliamDoane9
Trying to see the GUID for a replica
George_Thompson
Esri Notable Contributor
I am not sure that is exposed in the Pro tools. I see this: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/manage-geodatabase-replicas...
What do you need the replica GUID for?
Also, what version of the Enterprise Geodatabase / Pro is being used?
--- George T.
WilliamDoane9
Was trying to determine which Replica an exported xml update file referred to. Just re-exported the update from the correct Replica, but surprised there's no easy way to determine which Replica the export refers to.
MarlonAmaya
Hi @WilliamDoane9 ,
If you are working feature service replicas, you can see the Replica ID in ArcGIS Pro beginning with Pro 3.1.x. If you are working with traditional gdb replication, I would follow the above comment.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/manage-feature-service-repl...
Marlon
