I create a table in Oracle Database,but "Register with geodatabase" can not used
4144
06-25-2015 12:57 PM
xiaoyunnsongb
Hello superiors:
         I create a feature table in oracle use the sql
create table GC_GRID_TEST624
  objectid    INTEGER not null,
  shape       SDE.ST_GEOMETRY,
  gwm_fno     INTEGER,
  mme_eid     INTEGER,
  area_eid    INTEGER,
  name        NVARCHAR2(250),
  code        NVARCHAR2(250),
  label       VARCHAR2(250),
  create_date DATE,
  creator     NVARCHAR2(50),
  edit_date   DATE,
  editor      NVARCHAR2(50),
  group_name  NVARCHAR2(250),
  group_code  NVARCHAR2(250),
  subarea_eid INTEGER,
  dimension   NUMBER,
  holds       NUMBER,
  render      NUMBER,
  funds       NUMBER,
  qgall       NUMBER,
  fttho_yj    NUMBER(4,1),
  lan_yj      NUMBER,
  bak         VARCHAR2(255),
  grid_type   NUMBER
then  I want to use catalog to register the table  but the funtion is Grey and can't used,why ?
xiaoyunnsongb
JeffJacobson
This isn't the right forum for this question. Try this one: Geodatabase
