Having trouble refreshing a version
2065
09-29-2015 09:44 AM
LianePhillips
I am working in an environment with multiple editors.  I have created 2 child versions for each editor from the same parent version.  After the first editor makes changes and saves I have reconciled and posted the changes to the parent.  But when editor two does a refresh on their version they do not see editor one's updates.  The document is pretty clear and simple on how to do a refresh but I must be missing something.  The only way I can get editor two to see editor ones updates is to do a reconcile and post on editor twos version.  Any help is appreciated!
AsrujitSengupta
The behavior that you observe is as expected.
The second Version will not show the updated values without doing a Reconcile (Post not needed).
LitingCui
If those two editors are working on the same version, the second editor would be able to see the changes when he refresh. However, if the second user is connected to his own version, he won't be able to view the changes until reconcile from default version. This documentation has a very detailed explanation on how the version works:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
