Feature datasets in an Enterprise Geodatabase
955
10-05-2020 09:56 AM
DaltonBloom
Has anyone encountered errors after renaming a feature dataset within an Enterprise geodatabase?
Example: After renaming the title of a feature dataset, we were no longer able to make edits to the layers contained within that feature dataset. We've also encountered similar issues after renaming layers within a feature dataset.
We have since solved the editing issues by moving all layers out of the feature dataset, but would like to hear if others have come across any similar issues.
se2539
Did you register the feature dataset as versioned after renaming it?  Not having it registered as versioned would produce that behavior.  Also, was there a particular error message it produced when y'all tried to edit the feature classes within?
