Failed to execute (CopyRaster)
4649
02-11-2019 04:35 AM
All_Ukrainian_Associationof_Vi
Can`t import Raster Dataset into geodatabase (Postgres) from ArcMap 10.6.1
Failed to convert C:\Users\user\Desktop\1.jpg. ERROR 999999: Error executing function.
No raster store is configurated.
Failed to execute (CopyRaster).
Import from older ArcMap versions is OK.
George_Thompson
Esri Notable Contributor
Is there a reason that you need the raster in the geodatabase?
I would suggest storing the raster on disk, then access via Mosaic Dataset: What is a mosaic dataset?—Help | ArcGIS Desktop
What is the config keyword being used for the raster storage?
Convert raster data from ST_Raster to RASTERBLOB storage—Help | ArcGIS Desktop
PostgreSQL configuration parameters—Help | ArcGIS Desktop  - Look at the "Raster table parameters" section
Raster datasets and raster catalogs in a geodatabase in PostgreSQL—Help | ArcGIS Desktop
--- George T.
Asrujit_SenGupta
Check if this patch helps, if you are using 10.6.1:
ArcGIS (Desktop, Server) 10.6.1 Raster Patch
Thank you very much. It works
