EXTPROC setting for ST_GEOM
2552
01-13-2022 12:54 AM
yockee
I am having problem in querying using ST_GEOM. I have followed the guideline but without result.
Here is the error i get when i do query "select sde.ST_AsText(SDE.ST_Geometry('POINT (10 10)', 0)) from dual;"
I have also modified extproc.ora by adding this line : SET EXTPROC_DLLS=ANY.
But the result is still the same.
Anybody knows what may be the cause ? How to fix this ?
Thanks
George_Thompson
Esri Notable Contributor
Run the following SQL as the SDE user:
SELECT file_spec
 FROM user_libraries
 WHERE library_name = 'ST_SHAPELIB';
If the path returned does NOT match your ST_SHAPELIB location, please update it:
CREATE or REPLACE LIBRARY ST_SHAPELIB
 AS '<Location of ST_SHAPELIB file>';
Then:
ALTER PACKAGE sde.st_geometry_shapelib_pkg COMPILE
 REUSE SETTINGS;
https://desktop.arcgis.com/en/arcmap/latest/manage-data/gdbs-in-oracle/configure-oracle-extproc.htm
This would work if you have already run the Create Enterprise Geodatabase or Create Spatial Type GP tools.
--- George T.
George_Thompson
SELECT file_spec
 FROM user_libraries
Then:
 REUSE SETTINGS;
--- George T.
PamelaLandy
I have done the procedure for the st_shapelib library. But the query :
is only correct for me for SDE schema. For other schemes I get error.
What can be caused this ?
George_Thompson
If it works in the SDE schema, it is configured properly (as far as I know).
To be honest - I have not run it from another schema.
--- George T.
