Exporting relationship classes to enterprise GDB
7977
11-23-2015 08:35 AM
GabrielYarlequé
Good morning,
I am exporting all my local content to an Oracle database, but I am not sure how to export the following feature dataset given that I have some relationship classes. What is the best option to export this content to my enterprise GDB without loosing the relationships?
Thanks for all your help
MichaelMiller2
I believe if you export the feature classes out as an XML workspace document, the related tables will import with the feature class.
MichaelMiller2
GabrielYarlequé
Thank you! I tried using an XML workspace document but at first it didnt work. I didnt notice that some of the fields had special caracteres such as °, %, µg and so on. I changed the fields' name, used XML and this time it work just fine.
JoshuaBixby
MVP Esteemed Contributor
Check out the Copy tool.  As the Usage notes cover:
  • Any data dependent on the input is also copied. For example, copying a feature class or table that is part of a relationship class also copies the relationship class. The same applies to a feature class that has feature-linked annotation, domains, subtypes, and indices—all are copied along with the feature class. Copying geometric networks, network datasets, and topologies also copies the participating feature classes.
GabrielYarlequé
Thank you! I also tried this option after changing the fields' name and it worked as well.
AsrujitSengupta
A manual Copy\Paste will work for this as well.
