Error Registering DataSource on ArcGIS Server
4328
8
09-30-2015 10:05 AM
DEVAPP
Hi at all,
i have istalled  on the same machine ArcGIS Desktop and ArcGIS Server.
So i have istalled a oracle client 32 bit to connection on Oracle by ArcMap, but ArcGIS Server is 64 bit so now when i try to registered the data source into ArcGIS Server Manager i recive this error:
Cannot connect to database because the database client software failed to load. Be sure the database client software is installed and configured correctly.
How i can resolve this problem?
Thanks
AsrujitSengupta
Right Click on 'My Computer' > Properties > Advanced system settings > Advanced > Environment Variables.. > Under 'System Variables' check for a variable named PATH
AsrujitSengupta
You will need both Oracle 64-bit and 32-bit clients. 32-bit for ArcGIS Desktop and 64-bit for ArcGIS Server.
In the Environment Variable, the path of the 64-bit Client should be ahead of the path for the 32-bit client. This way both ArcGIS Desktop and ArcGIS Server will work.
MichaelVolz
Esteemed Contributor
Can ArcGIS Pro be a client to create mapservices like ArcGIS Desktop is?  If this is the case, then you could setup an environment where you only need 64-bit client as Pro and Server are 64-bit apps.  Is this correct?
MichaelVolz
The first link says that this capability will be available in a future release.  Do you have any idea what that future release is? Could it be Pro 1.2 that is scheduled to be released in Q1 2016?
AsrujitSengupta
No, I am not aware if this is going to be a part of ArcGIS Pro 1.2.
Even the person answering there was not sure about the Dates and Version, so I think it is on the cards, but 'when', I don't know as off yet.
DEVAPP
What Environment Variable? ORACLE_HOME?
Thanks
AsrujitSengupta
DEVAPP
thanks for your help
