EgdbDatastore - defrag % vs Azure SQL Database defrag %
836
09-28-2023 11:35 AM
AntheaTung
Hello there!
We are using ArcGIS Enterprise 10.9.1 with Azure SQL Database.
The defrag % output from Egdb compare to Azure SQL Database query shows different values.  Wondering what could be the reason the values are different for the same table?
For example in the perf_FragmentedIndex tab in the export.xlsx file after a run:
Egdb perf_FragmentedIndex report shows 99.26% defrag:
database_name
owner
indexed_object_name
table_type
index_name
avg_fragmentation_in_percent
in_row_reserved_page_count
WATER
xx
WATERJUNCTIONOBJECT
User Table
UUID_51
99.25765543
3290
Azure defrag query shows 5.79% defrag:
schema_name
object_name
index_name
index_type
avg_page_space_used_in_percent
page_count
alloc_unit_type_desc
xx
WATERJUNCTIONOBJECT
UUID_51
NONCLUSTERED
5.79854208084824
96.4498393872004
3018
IN_ROW_DATA
SELECT OBJECT_SCHEMA_NAME(ips.object_id) AS schema_name,
       OBJECT_NAME(ips.object_id) AS object_name,
       i.name AS index_name,
       i.type_desc AS index_type,
       ips.avg_fragmentation_in_percent,
       ips.avg_page_space_used_in_percent,
       ips.page_count,
       ips.alloc_unit_type_desc
FROM sys.dm_db_index_physical_stats(DB_ID(), default, default, default, 'SAMPLED') AS ips
INNER JOIN sys.indexes AS i
ON ips.object_id = i.object_id
   AND
   ips.index_id = i.index_id
ORDER BY page_count DESC;
Thank you !
