Dropping a Field on Archive Enabled Dataset
1952
11-09-2016 02:21 AM
HiteshJilka
Hello, I am testing a scenario where if I drop a field on Archive enabled dataset it also deletes the same field on Archive table. But I wanted to preserve that field and its data on Archive table. Is it possible ?
I would not likely to disable archiving before deleting a field and re-enable it again as dropping a field can be done anytime and by anyone who is not aware of Archiving.
Also, is it possible to use the same archive table again after re-enabling Archive for same dataset ?
Asrujit_SenGupta
No, once you have disabled Archiving on the data, you cannot use the old Archive table while re-enabling Archiving again. Enhancements have been logged for this functionality.
NIM050307 - Option to attach the old archive table (_h) back to the original feature class on re-enabling archiving
The only option seems to be taking a separate backup of the History Table before you delete any field.
HiteshJilka
Thanks Asrujit, did you get any update on logged case NIM050307 ?
Asrujit_SenGupta
Not really. For an update you will need to contact Esri Technical Support or your local Esri Distributor.
