Database migration from SQL Server 2017 to Postgres
2123
02-16-2023 06:16 PM
yockee
I want to migrate from EGDB Sql Server into EGDB Postgresql. Here is the condition:
- EGDB Sql Server (non versioning) reside on VM. The size of the EGDB is not large, only 50GB
- EGDB Postgresql will be on the cloud
Questions:
1. What are the considerations I should take ? Is copy feature class to feature class suffice enough ?
2. There are BLOB fields containing photos. Will it be a smooth copying (say, using Export or Import tools or maybe feature class to feature class) between different databases ?
3. How can I do this in the quickest and most correct way possible ?
Thanks
George_Thompson
Esri Notable Contributor
The best (and safest) way I have seen this done is using the ArcGIS tools (copy / paste) from the old SQL Server (data owners) to the new PostgreSQL in the schemas that you want. Using that workflow will allow the conversion into the correct repository ("SDE / GDB") tables.
When you copy of the feature classes with the blobs, it should copy them over to the new EGDB without issue.
This is the quickest and safest way that I have seen.
No idea how long it will take to copy. It may be a safe idea to copy to a file geodatabase as a backup.
Referenced from my post here: https://community.esri.com/t5/geodatabase-questions/database-migration-from-oracle-12c-to-postgres/m...
--- George T.
George_Thompson
--- George T.
