Create tempfield in definition expression to use in REST Service
2828
01-14-2016 05:44 AM
BrianO_keefe
Honored Contributor
I'm asking if it is possible (not smart) to create a tempfield in an MXD Definition Expression that creates a tempfield which is a concantenation of a few other fields that will translate over to the REST service created by said MXD?
So to clarify. I want to do the following:
  1. Create MXD using Feature Class X
  2. Create Definition Expression that generates a TEMP FIELD (using SQL).
  3. Temp Field will be a concantenation of fields A + B + C
  4. Share MXD as a Service.
  5. Create Webmap.
  6. Use TempField from REST Service in Webmap.
Is this possible?
