ArcGIS Pro 2.6.8; Oracle 18c; 10.7.1 EGDB; SDE.ST_GEOMETRY
It seems like there are four different states a feature can be in:
select
objectid,
shape,
(shape).points as geometry,
sde.st_area(shape) as area,
sde.st_isempty(shape) as is_empty,
comment3,
(shape).entity,
sde.st_entity(shape),
(shape).numpts
from
infrastr.inf_record_spQuestion:
For testing purposes, how can I create a feature like the one in state #3, where the shape is not null, but the geometry is null?
I'm hoping to create such a feature using SQL. But I'm open to other techniques, too.
I think I found a way to do it using SQL:
insert into infrastr.inf_record_sp (objectid, shape) values (
sde.gdb_util.next_rowid('MY_OWNER', 'MY_TABLE'), --objectid
sde.st_geometry(16, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 300046, null)); --shape
commit; https://desktop.arcgis.com/en/arcmap/latest/manage-data/using-sql-with-gdbs/next-rowid.htm
I can query the new row to see what it looks like. It is in state #3.
If I edit that row using ArcGIS Pro (even just edit a non-spatial field), then Pro will automatically change it to state #2: geometry is not null.
It's also possible to import an XML Workspace Document that has features with "shape but no geometry". The geometry remains null upon import.
Of course, you'd need to have some features that are "shape but no geometry" to export in the first place. Importing an XML Workspace Document creates a new FC; we can't import to an existing FC.
