Check out replica gdb - cannot subset related attachments
881
05-15-2017 10:50 PM
AngusHooper
I am having inconsistent behavior between the distributed geodatabase toolbar 'create replica' tool and the Create Replica (data management) geoprocessing tool.
As it currently stands, the toolbar provides the functionality I am after.
Problem:
Any query or selection is honoured by both tools with regards to the checked-out geometries / features.
The distributed geodatabase toolbar create replica tool will check out ONLY the attachments that correspond to the selection.
Result = 5 features, 5 attachments. - this is what I want
The create replica geoprocessing tool will check out ALL the attachments but ONLY the selected features.
Result = 5 features, 21000 attachments.
GP tool params:
inputs are layers from the table of contents - referencing a specific version
CHECK_OUT
replicating to a file geodatabase
SIMPLE
ALL_ROWS
GET_RELATED
Any ideas?
The same issue is experienced when using an extent instead of a selection.##
Asrujit_SenGupta
MVP Regular Contributor
Maybe its better if you report this to Esri Tech Support and let them try and reproduce the behavior.
AngusHooper
For future reference, this was resolved with USE_DEFAULTS as the expand feature classes and tables optional parameter.
