Check out replica gdb - cannot subset related attachments
1615
05-15-2017 10:50 PM
AngusHooper
I am having inconsistent behavior between the distributed geodatabase toolbar 'create replica' tool and the Create Replica (data management) geoprocessing tool.
As it currently stands, the toolbar provides the functionality I am after.
Problem:
Any query or selection is honoured by both tools with regards to the checked-out geometries / features.
The distributed geodatabase toolbar create replica tool will check out ONLY the attachments that correspond to the selection.
Result = 5 features, 5 attachments. - this is what I want
The create replica geoprocessing tool will check out ALL the attachments but ONLY the selected features.
Result = 5 features, 21000 attachments.
GP tool params:
inputs are layers from the table of contents - referencing a specific version
CHECK_OUT
replicating to a file geodatabase
SIMPLE
ALL_ROWS
GET_RELATED
Any ideas?
The same issue is experienced when using an extent instead of a selection.##
Asrujit_SenGupta
Maybe its better if you report this to Esri Tech Support and let them try and reproduce the behavior.
AngusHooper
For future reference, this was resolved with USE_DEFAULTS as the expand feature classes and tables optional parameter.
