Change GDB Version in ArcCatalog?
1935
04-04-2019 05:07 PM
SeanBirney
I'm trying to switch to different a different user version (other than sde/default) in arccatalog using the following information from ESRI.    Connect to a specific geodatabase version—Help | ArcGIS Desktop
All my versions are listed in the transactional version dialogue box but the version never changes from default when selecting another version from the list. Is there an ingredient I'm missing?
Thanks for the help
leomonterol
Hello Sean,
Where is the sde connection file stored? (E.g ArcCatalog's Database Connections folder/other folder). I've seen this behavior when the user trying to change the versions does not have write permissions on the sde connection file.
Also, have you tried to create a new database connection and changing the Geodatabase version afterwards?
Regards,
Leo
leomonterol
Hello Sean,
Regards,
Leo
SeanBirney
Thanks Leo,
The location of the sde file was the problem, moved it to a more permission friendly environment and now the version change sticks.
Thanks again,  Sean
