Can you version Hosted Feature Layers?
2105
08-29-2024 12:02 PM
Andrew-Bowne
Recently we have been doing more work with Hosted Feature Layers.  Is it possible to branch version a hosted feature layer?  I've only been able to do it with feature layers published from an Enterprise Geodatabase.
MarceloMarques
@Andrew-Bowne
The data must be registered as branch versioned and published from an enterprise geodatabase.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/branch-version-scenarios.ht....
Enterprise Geodatabase = ArcSDE Geodatabase in Oracle, SQL Server, PostgreSQL.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/register-a-dataset-as-branc...
You cannot use branch version with hosted feature layers with ArcGIS Data Store.
I hope this clarifies your question.
Regards.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
@Andrew-Bowne
Regards.
Andrew-Bowne
Thanks @MarceloMarques this does answer my question.  Does the same stand true for Traditional Versioning?  That can also only be done on an Enterprise GDB?
MarceloMarques
Yes, the same applies for Traditional Versioning as well, you must have an ArcSDE Geodatabase in Oracle, SQL Server or PostgreSQL.
