Marcelo Marques - Oracle Restore Point and Enterprise Geodatabase Repository Upgrade
1480
09-03-2024 06:28 AM
JamesMorrison1
Hello Marcelo
Sorry to ask a direct question but I'm trying to fully understand what is happending with the SDE Tables and Stored Procedures in the SDE Schema. We plan to upgrade from 3.1  to 3.3 on Oracle 19.
In your excellent document you have the following steps.
7. Upgrade Geodatabase Repository
12. Update the ST_GEOMETRY library
So in Step 7 - the SDE Tables and Stored Procedures will get upgraded via ArcGIS Pro 3.3 At this point it does not matter if the ST_GEOMETRY library (libst_shapelib.so) are present on the server or not?
Thanks for the clarification.
MarceloMarques
@JamesMorrison1 - if the st_geometry library is not configured then the ArcGIS Pro Upgrade Geodatabase GP Tool will show a warning message, but the ArcSDE Repository upgrade shall work fine, after that you can configure the st_geometry library.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
JamesMorrison1
Great. And thanks for all the documentation you make. Helps so much.
MarceloMarques
You are welcome. I am glad the documentation is helpful.  : )
