Can not connect to sql server from Arc when firewalls are up
3500
07-31-2015 04:49 PM
RandallClark2
So i can not connect to my sql server (2014) from Arc when my firewalls are up even when i have an rule allowing in and out bound connections on the following ports 1433 (default) and 50102 (the port in use by my server), Thoughts?
i also set it up so that it is based on the program sqlservr.exe and not the ports but that does help either.
thanks
AsrujitSengupta
SQL Server uses 1433 and 1434. Add those to Firewall Exceptions Inbound\Outbound rules and then check.
