Can I change an existing field to coded domain
1699
05-10-2017 10:57 AM
LukeAllen1
Hi guys, I hope I am asking this in the right place.
I made a geodatabase with a field that is just a simple input text field that I have already filled with data. I would like to change this field to a coded domain / drop down menu selection field.
Is this possibly to do considering I already created a field which is populated with data?
Thanks!
Luke
Edit: Thank you George, my bad!
George_Thompson
Esri Notable Contributor
Added a broader audience: https://community.esri.com/groups/geodatabase?sr=search&searchId=6be0a083-286e-4d93-9ddb-274982e00e2...
The GeoNet Help section is for questions related to GeoNet, not the Esri software
--- George T.
Asrujit_SenGupta
Yes, you can add Domain to an existing field with Data in it.
Adding of the Domain will not affect\modify the existing data. After adding the domain, when you start editing again on that field, then you only get the options that were listed in that Domain.
