I would like to know if it's possible to add Geodatabase Enterprise (v10.5 or 10.6) on Microsoft Azure SQL Database (not SQL Server on Azure VM) ?
I found this but it's old :
System Requirements
ArcGIS geodatabases are not supported with Windows Azure SQL Database.
I also found this subject and I'm not sure if it's about sql server on Azure VM or Azure SQL Database :
Functionality differences for geodatabases in Azure SQL Database—ArcGIS Enterprise | ArcGIS Enterpri...
Use either Microsoft Geometry or Geography data types for the spatial fields in your feature classes; sdebinary storage is not supported.
What does that means ? If I had a geodatabase enterprise on SQL Server can I copy and past to and Geodatabase enterprise on Microsoft Azure SQL ?
Sylvain.
