Build Geometric Network (Before to recreate)
2975
6
06-30-2017 10:51 AM
paulomoraes
Hello,
Anyone can help me, about this erro below:
Build Geometric Network failed.
Invalid network name. (The feature class RedeDeAgua_Net_Junctions already exists.)
OK
It's happen when Try to recreate a geometric network, how to clear or repair  this?
Tags (1)
George_Thompson
Esri Notable Contributor
You can only "build" the Geometric Network (GN) once. Once it has been built, then you can "rebuild" sections as needed. About Verify Network tools and commands—Help | ArcGIS Desktop
Based on the error above, you may need to completely delete your GN and then build a new one from scratch.
https://community.esri.com/groups/geodatabase?sr=search&searchId=341f645d-8eb1-40ab-abd8-711e640eb4a...
--- George T.
paulomoraes
George Thompson,
I cant built because this error:
and cant rebuild because not visible RedeDeAgua_Net_Junctions on my feature dataset
George_Thompson
Did you delete the original network first?
--- George T.
paulomoraes
Yes.
George_Thompson
Ok, sounds like there are some orphaned objects in the geodatabase. You may need to get a new Esri Support case opened with an analyst to review and see what can be done.
#esri technical support
--- George T.
paulomoraes
Another try, I give :
Cannot create the geometric network.
Table already exists [42S01:[Microsoft][ODBC Driver 11 for SQL Server][SQL Server]There is already an object named 'N_1_PROPS' in the database.] [giscomptecnicos.DBO.N_1_Props]
DBMS table not found
OK
