Blog discussion - Migrating from Personal GDB's to...
5699
13
05-25-2022 11:42 AM
ElaineEvans
The first of a series of blogs was released to discuss why personal geodatabases are not supported within ArcGIS Pro.   Additional blogs within this series have also been released and further explore options such as:
  • Using OLE DB to establish a read-only connection from ArcGIS Pro to your personal geodatabase.
  • Table comparing the differences between file-based geodatabases (mobile, file, and personal geodatabases)
  • Migrating data from a personal geodatabase to a file geodatabase.
  • Migrating data from a file geodatabase to a mobile geodatabase.
An additional blog will be released soon within this series and will further explore:
  • Reporting options available to use with your mobile geodatabase.
This discussion is for questions that are directly related to content/concepts included in these specific blogs:
curtvprice
Just a little comment, I strongly suggest you mention right at the get go (under the heading "Data Migration Tools) that ArcMap is required so those of us that have lost access to ArcMap know that OLE is our only path in to be able to extract (only tabular) data from personal gdbs. Thanks again for a really great blog series.
xingchenc
@ElaineEvans
It would make much sense to provide a convertion tool(mdb to gdb) in ArcGIS Pro environment. After migrating to ArcGIS Pro, I doubt anyone would still paying for the ArcMap license!
RobertoRossi
@xingchenc, I understood that what you ask it's not possible because some libraries needed to read mdb are not available in 64 -bit environment.
Maybe @ElaineEvans Esri should consider to provide a stand alone tool, or a web tool where we can load our mdb and download a gdb, when ArcMap Licence will not be available any more (march 2025 for my organization).
xingchenc
Yes, a stand alone tool would be great!
