Are FGDBs an extension of a different database engine under the hood?
1435
12-05-2022 08:41 AM
Bud
Esteemed Contributor
Are file geodatabases an extension of a different kind of database engine under the hood? For example, are FGDBs a customized version of an SQLite database?
I'm aware that FGDBs are proprietary and inaccessible outside of ArcObjects. But it would still be helpful to know what kind of database Esri might have started with when architecting FGDBs. I assume the core non-spatial database component wasn't built 100% from scratch.
Knowing what the original database was would help inform how we use SQL when writing SQL expressions on FGDBs in ArcGIS. Or even when writing database views on FGDBs*.
Thanks.
Bud
*I learned recently that it's possible to create a database view on an FGDB. Which is very interesting.
Create Database View (Data Management)“This tool is supported for databases, enterprise geodatabases, mobile geodatabases, and file geodatabases.”
Related:
VinceAngelo
Esri Esteemed Contributor
No, there is no "original database" for file geodatabase. It was created as a replacement for the Access-based "personal geodatabase" and as a lesser-complexity sibling of enterprise geodatabases. It is NOT based on any database (and if you look at the implentation, you can see the Esri VFILE lineage with INFO flair)..
- V
BTW: "inaccessible outside of ArcObjects" is not quite accurate, since the FileGDB API provides third-party access.
Bud
For what it's worth, the docs say this about the SQL syntax used by FGDBs:
SQL reference for query expressions used in ArcGIS
All SQL used by the file geodatabase is based on the SQL-92 standard.
That doesn't address the original question, but it does help clarify what kind of SQL the FGDB uses.
Related: SQL for reporting and analysis on file geodatabases
