When creating a view in a file geodatabase, using the Create Database View tool, in the view definition, any / character I use for division disappears when I run the process. This of course throws a generic "invalid SQL statement" error (160195). Leaving out the division problem works fine (in other words, running a query in a file gdb with summing and grouping are just fine).
The view definition would be:
select NEW_COMMDIST AS New_Comm_District, sum (pop2020) AS Pop_per_Comm_District, CAST (sum pop2020 AS float) / 32250.0 AS Deviation FROM pro2 GROUP BY new_commdist
Literally after running this, the query becomes:
select NEW_COMMDIST AS New_Comm_District, sum (pop2020) AS Pop_per_Comm_District, CAST (sum pop2020 AS float) 32250.0 AS Deviation FROM pro2 GROUP BY new_commdist (note the missing /).
This is in Arc Pro 2.8.3. I tried a CAST function because I thought maybe the / operator might require 2 floats. The problem exists with 2 integers also.
Are there any fancy character workarounds I can try? or is there a DIV () function maybe?
Thanks all.
