Invalid Terminal Configuration error at 2.3
3469
6
01-30-2019 08:43 AM
MarkCederholm
My network configuration (based on UPDM) which worked fine at 2.2 is failing at 2.3.  My customer meters are at the default single terminal configuration, and when I enable topology, every single meter gets error type 39 "Point feature has invalid terminal configuration".  Has anyone else seen this issue?
PaulLeBlanc1
Well the default value for the field is 'Default', so it should be populated.
PaulLeBlanc1
Error 39 means the terminal path is invalid.
Error feature management—ArcGIS Pro | ArcGIS Desktop
What values do you see in Terminal path?
MarkCederholm
I don't populate a value.  Do I need to change that to "Default" now for all single terminal devices?
PaulLeBlanc1
MarkCederholm
OK, I'll update my script to see if that fixes things.
MarkCederholm
That did the trick, thanks.  I'm surprised the default value wasn't automatically filled when I populated the asset package.
MarkCederholm
This might be the issue: I create connectivity associations between each meter and a junction so that I can have multiple meters per assembly.  Here's an example of an association record that I import:
ASSOCIATIONTYPE,FROMFEATURECLASS,FROMASSETGROUP,FROMASSETTYPE,FROMGLOBALID,FROMTERMINAL,TOFEATURECLASS,TOASSETGROUP,TOASSETTYPE,TOGLOBALID,TOTERMINAL,ISCONTENTVISIBLE
Junction Junction Connectivity,PipelineDevice,Meter,Customer,{31C37CF7-CF62-4700-BB1D-90EDEC05F4FD},Single Terminal,PipelineJunction,Connection Point,Riser Connection,{06AD49ED-BE80-4DC5-ACD5-C28436EC0DC4},Single Terminal,
Is there something I need to change?
