Exclude abandoned pipes on gas tracing??
980
02-27-2019 12:15 PM
Pei-yuChen1
Some of our existing gas data have abandoned pipes connected to operating (active) pipes through a gas fitting (edge-junction-edge connectivity).
Is it possible to configure the utility network to exclude abandoned pipes when running pipe tracing?
Any response is highly appreciated!
PaulLeBlanc1
You can assign a network attribute on the field that stores the active state and then set up a condition barrier.
Here's what that looks like in the Gas Utility Network Configuration
Pei-yuChen1
Is there any tool allowing users to change or modify the configurations after the Utility Network have been created and published?
Thanks!
PaulLeBlanc1
These are just the default values from the subnetwork definition. When you are running a trace, you can override them.
If you need to add a new network attribute, you'll need to stop the service disable topology to modify that.
