.cor to Shapefile - Conversion Problem
11432
7
04-20-2016 01:59 PM
ElizabethHigh
Using Pathfinder Office, I'm trying to convert a .cor file (differentially corrected GPS data) to a shapefile, but am only getting a .inf file and a .txt. file as a result. Does this mean the original data collected was corrupted? I didn't collect it and don't have the original data on the GPS, so I'm just working with .cor files sent to me.
Tags (3)
DanPatterson_Retired
from all the old threads  using .... Pathfinder Office ... as a key search phrase, it seems that you export to shapefile from there, and the inf and cor files are native to that software.  What is he procedure you are using? a save? or an export to shapefile?\
ElizabethHigh
Thanks, Dan. I've done it many, many times with no problems, but in those instances, I did the differential correction of the raw data myself. The procedure I use is :
-In Utilities menu, choose "Export..."
-Browse to the .COR file I want to export and choose it
-Browse to and choose the output file I want
-I already have all the Properties checked that I want, but I did double check those, just in case
-Then I press "Ok."
     -It always prompts me to remind me that I don't have a coordinate system chosen (I leave WGS 84 as the default, then define it in Arc because I've had better results doing it this way), so I just tell it to continue and  then it exports.
Hmmmm don't use it, but I certainly don't like the fact that the data doesn't have a defined coordinate system first, before you export.  You should be able to set it then export.  And as a backup, export the file to as many different formats as humanly possible, *.csv, *.txt  in comma or tab separated AND to a shapefile.  One of those formats should be able to be read unless there is something wrong with the inputs (null objects etc) or the extents are wildly wrong.
ElizabethHigh
I think there's something wrong with the data. I'm going to try to get the raw data and re-correct it, then see if it works. I'll let you guys know if I figure something out.
keep us posted then
JayantaPoddar
Check the correct answer in the following link for a few additional steps in Pathfinder Office.
convert - Converting GeoExplorer gps data points - Geographic Information Systems Stack Exchange
Think Location
ElizabethHigh
Thanks, Jayanta. I tried those tricks just in case, but it didn't make a difference. I've always been able to export with no problems, but I've previously done the differential correction of the raw data myself. That's why I think this problem may be related to how the correction was done, or something like that.
