using Stored procedures to update a Featureclass inside a FileGeodatabase
2499
06-15-2012 01:32 PM
Jose_LuisGarcinuno-Oporto
HI, I wonder if someone can give me a help, it is possible to use Stored Procedures (SP) to update a FeatureClass outside an edit sesion?, I was able to connect to the FileGeodatabase through my C# apps but I reached the point WHERE? should I be stored my SPs. FileGeodatabse does not have the same structure like Personal Geodatabase.
Any help will be very welcome.
VinceAngelo
Esri Esteemed Contributor
Personal geodatabases are implemented on top of the Microsoft Jet engine (Access),
ArcSDE geodatabases are implemented on SQL RDBMSes, but FileGeodatabases are
standalone.  There is no SQL engine to implement stored procedures, so you can't
use them to update anything.
- V
Thanks very much, clear enough.
