Spatial Reference Info
5420
11
02-18-2011 01:28 AM
ahuarte
Hi!
I need read the SpatialReference info of a FeatureClass.
XML samples in the doc-SDK contains this description (WKT, WKID...) but calling to Table::GetDefinition() function it always returns no data.
I have test all sample gdb files and other personal gdb files FgdbV10.
What it's wrong?
thank you very much
LanceShipman
The following code produces XML with the spatial information:
  // Open the geodatabase.
  int hr;
  Geodatabase geodatabase;
  if ((hr = OpenGeodatabase(L"../data/ctg94AllDataset.gdb", geodatabase)) != S_OK)
    wcout << "An error occurred while opening the geodatabase." << endl;
    wcout << "Error code: " << hr << endl;
    return -1;
  // Open the ManyFieldTypes table.
  Table table;
  if ((hr = geodatabase.OpenTable(L"\\ctg83FDS\\ctg83FCinTopo", table)) != S_OK)
    wcout << "An error occurred while opening the table." << endl;
    return -1;
  // GetDefitition
  wcout << "Test GetDefitition:" << endl;
  string xmlDef;
  if ((hr = table.GetDefinition(xmlDef)) != S_OK)
    wcout << "An error occurred getting the table definition." << endl;
    return -1;
  cout << xmlDef << endl;
I've attached the XML that this code produces.
ahuarte
thanks your reply
I am confused. I get this XML reading the ExecuteSQL-cities gdb sample from the sdk.
It have not WKT and WKID info and Table::getDefinition returns me the -2147211775 error code.
The table was opened success.
All samples from SDK and my gdbv10 files return equals.
why ¿?
LanceShipman
thanks your reply
What beta are you using we have released 2. I get the WKT in the XML. When does the error get returned? It's an item not found error. Can you post your code?
why ¿?
I'm sorry, I don't understand. What returns equals?
ahuarte
I use the beta release 2.
my code...
  std::wstring tempString = L"";
  Helper_MarshalString(tableName, tempString);
  m_pDatabase = database->m_pDatabase;
  m_pTable = new FileGDBAPI::Table();
  long hr = m_pDatabase->OpenTable(tempString, *m_pTable);
  if (hr==S_OK) return false;
  std::string tempString2 = "";
  long hr = m_pTable->GetDefinition(tempString2); //-> ### ERROR -2147211775
tempString2 has XML content but NO WKT info!
all samples and my FGDB files (Imported in ArcCatalog 10 from shapefiles) return this error.
Sorry my bad english!
Thank you very much
LanceShipman
my code...
Thank you very much
What version of Winodow and Visual Studio are you using?
ahuarte
I use
- Windows XP 32bits SP3 (spanish)
- Visual Studio 2008 9.0.30729.1 SP (english)
LanceShipman
if (hr==S_OK) return false; <- this is incorrect.
if (hr != S_OK) return false
S_OK (0) indicates success. The likely problem is that the table name is incorrect. Using
if(hr==S_OK) return false
the code will only continue executing if OpenTable fails. Any results from the GetDefinition is an error.
Do the samples execute for you?
ahuarte
I'm sorry, I copied the wrong code.
Please, ignore... "if (hr==S_OK) return false;" <- this is incorrect
XML file that I sent is the example "ExecuteSQL.gdb"
thak you very much!!!!
LanceShipman
Do the samples execute? This is important. We have tested the samples on most Windows platforms and have never seen a problem.
