read ESRI FileGeoDataBase / sql filter on date field
3647
07-17-2013 04:23 AM
RalfWessels
hello,
I have a file geodatabase (10.1) and want to read out data by SQL-select on date fields, but I can`t get it working.
..tried the following codes:
....where date_field < '2013/07/09 17:34:49'
....where date_field < '2013-07-09 17:34:49'
....where "date_field" < date '2013-07-09 17:34:49'
but nothing works.
ralf
LanceShipman
This "date_field < date '2013-07-09 17:34:49' " should work.
  EnumRows attrQueryRows;
  if ((hr = table.Search(L"*", L"UP_DATE > date '2007-05-23 11:13:59'", true, attrQueryRows)) != S_OK)
    wcout << "An error occurred while performing the attribute query." << endl;
    ErrorInfo::GetErrorDescription(hr, errorText);
    wcout << errorText << "(" << hr << ")." << endl;
    return -1;
RalfWessels
hi Lance,
Great, it works - thanx a lot for that quick answer
best greetings from Berlin
Ralf Wessels
