Polygons with arcs do not have the correct area
18364
36
01-08-2016 08:59 AM
DonnyVelazquez
It appears there's a bug in the fgdapi when inserting polygons with arcs. It doesn't calculate the area correctly. It only calculates the straight sides and does not include the area the arc is creating. Once you run it through repair geometry, it fixes the calculation.
Anyone else run across this? Vince Angelo
DonnyVelazquez
NeilAyres
Phew...
I'm really glad I just stick to python / arcpy....
mbonacia
Hi Donny,
Do you have any sample on how to work with curves using this API? mostly reading the curves points of a polygon
Any help is appreciated
Thanks!
Martin
DonnyVelazquez
Your better off using GDAL. ESRI hasn't updated the File Geodatabase API in over 7 years. It looks like they have abandoned it. I use Gdal.net Core, has way more features, including arcs. You can export to FGDB and a bunch of other formats.
https://github.com/MaxRev-Dev/gdal.netcore
mbonacia
Hi Donny,
I'm sorry I did not reply before. I had to switch gears to another project and now this subject is back to the working table. Even though I have the latest ESRIFileGDB API (FileGeodatabase API_1.5.4) for VS2022, it appears there is still not a way to handle curves/arcs. Have you found a way to create polygons that include arcs/curves? If not, could you provide a sample using GDAL as you suggested in your last reply?
Thanks!
DonnyVelazquez
mbonacia
very clever.... thanks!
