How to use the File Geodatabase API c++ libraries into .NET Projects?
5001
6
01-21-2011 02:12 AM
Francisco_J_RP
Dear friends,
I need to use the Geodatabase File API c++ libraries into my .NET applications.
What are the tasks that we need to make use of these?
Thanks in advanced.
Francisco J.
Patrickvan_Dijk
There is two ways you can accomplish this
1) Create a DLL from this LIB in which you expose a certain API you like.
Then from .NET use P/Invoke to you custom DLL.
2) Create a Mixed Mode DLL containing both Native and .NET instructions.
Most of the times I prefer to use a Mixed Mode DLL.
Regards,
Patrick
Francisco_J_RP
Dear Patrick, many thanks for your reply.
Do you know any sample applied to any LIB to learn how can I apply to the Geodatabase API Lib?
I'm a recently .NET programmer and I don't have any knowledge about C++ programming and interoperability with .NET languages.
If I don't have access to the source code except the headers files with the scheme of functions, methods, ... Can I use your methodology to get access to custom object as geodatabase, rows, features, ...?
Thanks in advanced.
Francisco J.
MarcBate
Ditto.  I'd like an API I can use with .NET and ArcGIS Explorer, for example, that allows me to read/write feature classes in a file GDB with my plug-in.
DonnyVelazquez
I created an example project that is a CLR C++ wrapper for the FileGDAPI. You can use it from any DotNet language to access the api. That should get the ball moving.
http://code.google.com/p/filegdbapi-dotnet-example/
PrateekBansal
Hey ,
I tried using the sample project but whenever I try to open or create a geodatabase I get this error
Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Any Idea how this can be resolved ?
Thanks
Prateek
LanceShipman
We will be releasing a .NET Wrapper sometime in the next week or two. Watch the geodatabase blog for the announcement.
http://blogs.esri.com/Dev/blogs/geodatabase/default.aspx
