how to use Shape in FileGDBAPI.table search whereclause
1339
03-02-2017 09:34 AM
LiChou
hi, I am new to GIS and also FileGDBAPI C.  I am trying to query the geodatabase using Point's x, y, z .  I can't find in anywhere for the format of using Shape in where clause or is it possible to use Table.Search to query geodatabase?  Thanks.
JoshuaBixby
See Using the File Geodatabase API from the 2015 DevSummit proceedings:
  • Perform attribute and (limited) spatial queries on datasets
    • Spatial queries are limited to the envelope-intersects operator
Although I am not exactly clear what you are trying to do, I am under the impression it isn't going to work.  If doing an envelope-intersects operator will suffice for your needs, the envelope can be defined and passed to the table search function along with your whereClause.
LiChou
hi Joshua, thank  you for your reply.
I am trying to export our gis data from our sqlite db to the geodatabase.  Both databases have the same points coordinates info, and I need to query the geodatabase to get the OBJECTID in order to update its gis data.  I assume I need to do something like
SELECT OBJECTID FROM coord WHERE coord.Shape = '(x, y)';
I am not sure what envelope-interset operator, but I will look up.
The Using the File Geodatabase API is half white out, so I can't read.
Thank you.
