File Geodatabase API / FullExtent and RecordCount ¿?
1382
01-24-2011 09:48 PM
ahuarte
I am reading a FeatureLayer table using the C++ API.
Congratulations! I love this library 🙂
How I do to read the FullExtent and the RecordCount of the table?
Should I read whole table and manually calculate it?
But if it is very very big?
This does not work ...
  std:: wstring sqlStatement(L"SELECT COUNT(OBJECTID) AS __NUMRECS FROM Cities");
Could you publish this information in the following version of the API?
thanks in avance!
LanceShipman
Currently there is no way to read the FullExtent or the RecordCount of the table except by manually calculating it.
SELECT COUNT() is not supported by the file geodatabase. When it is we will add support to the API.
I will enter enhancements for both of these issues (to be included in a later release.)
ahuarte
Thanks for the reply.
I think 🙂 that 'COUNT()' is not necesary if exist a property 'RecordCount' in your 'Table' class.
Thank you vey much.
LanceShipman
GetRowCount and GetExtent will be in the next Beta code drop.
