File Geodatabase API 1.2 now available
5378
6
03-07-2012 12:22 PM
LanceShipman
The File Geodatabase API 1.2 is now available for download from the resource center. (http://resources.arcgis.com/content/geodatabases/10.0/file-gdb-api)
What�??s new at 1.2:
    * Support for Intel-based Mac. The minimum supported OS is Snow Leopard 10.6.  The supported compiler is gcc 4.2.1.
    * Macros for error values allowing for more readable code. (NIM077630)
    * HRESULT IFDEFs have been updated to define if they are not set. (NIM071619)
    * File Geodatabase API function parameters are const ref's where possible. (NIM071620)
    * Coordinate systems supported updated to match ArcGIS 10.1. (NIM078034)
    * Structure definitions for curves (CircularArcCurve, BezierCurve, EllipticArcCurve).
Fixed Issues:
    NIM071538 The spatial index is not used in a spatial search.
    NIM072876 Dates are not correctly read or assigned when using the File Geodatabase API .NET wrapper.
    NIM074135 You cannot assign a domain to a table created with the API.
    NIM077629 Correct the Bezier curve buffer documentation in the extended_shapefile_format.pdf, the stated size is wrong.
    NIM075930 DeleteGeodatabase crashes intermittently.
    NIM076353 Row.SetGUID fails to set a value with the .NET wrapper.
    NIM077138 Table extents truncated, breaking spatial indexes.
    NIM078028  Fix the Mutlipatch Shapebuffer helper function.
KyleShannon
Any reason why the name of the library was changed from:
libfgdblinuxrtl.so
to
libfgdbunixrtl.so
?  Just curious, it messed with my builds.
LanceShipman
We renamed it to make it more generic. It didn't make sense to keep 'linux' in the name now that we have a Mac release.
Since Linux and Mac are both 'Unix'-based or Unix-like under the hood, we thought libfgdbunixrtl.so made sense.
adamestrada
I cannot get GDAL to build anymore with this library. http://trac.osgeo.org/gdal/ticket/4588
Any thoughts on what I might be doing wrong on my 64bit CENTOS box? Suggestions on getting it to work?
Adam
PaulAustin
Any chance that you could create a single download for all platforms for the next release?
In that download there would be one set of headers that would work for all platforms. The different dll/so libraries or build scripts would be in appropriate sub folders based on platform and architecture.
PaulAustin
Also is there any chance that there could be a Windows version of the library that can be linked to using GCC rather than Visual Studio?
Paul
LanceShipman
You should add these requests to the ESRI ideas site. http://ideas.arcgis.com
