FGDB ODBC driver?
3804
6
05-26-2011 10:21 AM
ChrisSnyder
Honored Contributor
Is there an easy pre-built ODBC driver (or whatever?) that I can install on my machine so that Access or Excel can directly read tables frorm a FGDB? Forgive my ignorance if this is a silly question...
LanceShipman
There is no pre-built ODBC driver for the File Geodatabase. It would be possible to write one using the API.
ChrisSnyder
Honored Contributor
Hmmm... Any chance that ESRI will do that (write a driver) anytime soon? I don't think I have the skillset to pull that off!
JustinHill1
I am looking for the same thing. Have you found an FGBD ODBC solution yet?
Thanks!
Justin
LanceShipman
Add your request to http://ideas.arcgis.com/ideaView?id=08730000000887yAAA on the idea site.
ChrisSnyder
Honored Contributor
Might be useful to have some communication from ESRI as to why this hasn't been implemented yet. This particular idea was submitted 3.5 years ago and clearly has broad user demand, but yet it is listed as "Deferred". I get the feeling that for some of these things, we can up vote ideas till the cows come home, but...
Some official explanation might be useful (32 vs. 64 bit compatibility issues or something?), since the lack of communication on some of these topics, in my opinion, often makes ESRI look unresponsive and foments user frustrations. Maybe if an idea attains a certain point level, but is impractical to implement for some technical reason, there could be an official post from ESRI staff providing a high level explanation what the holdup is.
SimonNorris
Dump your data to sqlite or postgres.
